Spray insulating foam & mains cables
12 Feb 2009
London
All,
Not sure whether this is a problem or not... I have a large hole through one of my outside walls near my front door where electrical cables pass through from the ground floor to the top floor.
Can I fill this hole with insulating foam or is this likely to introduce a fire hazard?
cheers
Eggers
I guess I'm more interested in whether putting this insulation into the walls around the wires will introduce a fire hazard from the cable overheating.... If that's the case then I probably shouldn't use insulation at all.....
