I was wondering if anyone has experience spraying Zinsser Bullseye 123 primer with an HVLP?
I just repainted an internal door at the weekend, first priming it using BIN with a foam roller and then spraying scuff x with a HVLP. There was clear orange peel effect after the BIN. The result is ok after 2 topcoats but there is some orange peel showing through in parts.
I was thinking next time spraying the primer and using Bullseye 123 instead as it's WB so easier to cleanup in the sprayer?
