Hay everyone, I had my end wall taken out in my Victoria terrace, the structure engineer used a portal box frame with a RSJ in the floor (spreader beam) and one supporting the bricks above and the RSJ's separated by two posts that are bolted into the walls.
This has been done.
The engineers words say that the spreader beam should sit on the houses existing foundations.
When building control came out they said they would not approve the steal work as they need to see what it's sitting on as the builder put concrete ether side.
Today I have dug out either side of the RSJ to look under it.
Now it site on concrete that was poured into the floor as the existing bricks did not go deep enough and were removed to get the RSJ in.
So it turns out that the RSJ is sitting on around 50mm of concrete where the bottom of the existing wall was.
Under this is just clay I suppose how it was built originally.
How are building control going to insist it must be on existing foundations if the never were any and the wall was originally built on clay?
Will they accept this or will I have to put in a foundation?
Ay ideas?
Can I argue there choice considering the wall was already there.
I'll post a picture if needed.
Cheers all desperate for some form of info
This has been done.
Ay ideas?
