Spreading lap joint!
3 Nov 2010
Hampshire
Morning,
I have just been asked by my neighbour to have a look at a problem with her roof.
The property is a bungalow and has a cut roof. The purlin running around the interior of the roof has come apart in one place just short of a strut. I'm assuming the lap joint should have been the other way up so the joints are always forced together...
Regardless the roof does have a noticeable hollow in it viewed from outside and the purlin has separated by approx 2" or 50mm on the inside.
She has no idea how long it's been like this...
The question: Would it be wise to simply clamp the lap joint back together put a coach bolt through it and then bolt a section of timber across the side of the joint to strengthen it? It should be quite straightforward but if the joists have been displaced for any significant period of time they may now be bowed and reluctant to go back to position. I don't want to simply make it worse! Or should I clamp it all up in it's current position.
What would you do?
Cheers guys
It may be very difficult to lift the purlin (and rafters) back up now
Use some ply or timber across the joint (bother sides) to prevent further movement
Don't try to force it back it'll only cause problems. Do as woody says although I'd personally use steel straps . I can't recall exactly what they are called but it's possible to get straps off the shelf around a meter long by 40mm x 5mm (ish) with holes that can be simply screwed in place.
