Sprung a leek advice needed asap please
6 May 2007
Lincolnshire
Just been out to my garage and there is a leak above my boiler a fast flowing one to , it is coming out of a blue what seems to be a presure type thing on the cold feed to combi boiler, it has got a tyre type valve on the top, it has failed somewhere around the lip. Need to know what this thing is called so I can source another one asap. Cheers in advance of any help
Expansion vessel.
Frank
Mini expansion vessel.
Just a thought , its only about 10 months old , is it common for these to fail? It s exactly the same one as in Robs pic and was fitted with a new boiler.
All sorted folks , thanks for your speedy info.Hope I can return the advice someday to you in the building section. :D Plumber said must have been a bad batch has had the same problem a few times recently
