First of all this a diy site, and the answer I gave the op is 100% correct because it covers all possible configurations of the existing power circuit.
Which are limitless. How do you know you're not suggesting a contravention of 433.1.5? Or even 411.3.2.2? Or section 525?
And then two people introduce nonsense replies that in no way assist the op. More importantly the replies are based on using some words that they like and ignoring words they don't like.
In what way did my reply make no sense?
Or, to put it another way " I want to do something that I think is incorrect and defies logic, but if I can find some words in the regs that make it seem correct, it will be ok"
There are so many assumptions and insults in there that it's not worth bothering to see whether it can be turned into a question. All I did was politely suggest that you may not be correct in your assumptions and you start mouthing off. Grow up
mfarrow said:
433.2.2 and 433.3.1(ii) say otherwise,
Do they really, well ony if you ignore the conditions laid out in section 434, both of the regs you quote actually state that they depend on compliance with sect 434. Read all the words, not just the ones that suit you.
Read my reply. You gave a blanket statement that 1.5 was too small, to which I gave two regulations for which it may be permitted. In no way did I say to ignore any of the wording in those regulations, including reference to section 434.
A 1.5 cable will take 272A for 0.4 seconds, assuming the breaker take that long to trip. If the circuit was designed properly, this
may be sufficient for a B32 breaker under fault conditions, and again
may be sufficient for a B6 breaker. But this is dependant on the PFC and characteristics of the protective devices. Have you got that information holmslaw?
All a bit academic anyway seeing that 2.5 T&E has a 1.5 cpc in itself.
however is it's a final ring circuit the specifics of 433.1.5 would mean 1.5 is unacceptable.
But if its a ring its unacceptable, what sort of circuits do you normally find in houses?
And if it was a 20A or 32A radial, would that be acceptable or unacceptable? I'll answer for you, it would be totally unacceptable.
It is
you choose to ignore the regulations that apply and only read the ones you want.
The simple fact is, regardless of our debate as to what I was saying in my reply, the OP has gone away and may have extended a double spur off a ring circuit, which is 1/2 mile away from the consumer unit, with a poor main earth. But I guess we'll never know that now, or how many people died in the fire.
