Square tap holes in bath!
16 Feb 2004
Hi everyone
I'm in the process of putting a new mixer tap in our bath. I took out the old taps and the holes that were left in the bath are square.
My new taps are round and when I put my new taps in, you can see the corners of the square holes and this would not be a watertight seal.
Is there anywhere were I can get some sort of adaptor to get round this problem.
Thanks in advance
Gary.
The washers should cover it...if not pop to your friendly plumbers merchant and see if they have some slightly bigger washers lying around.
Hi Ollski
I've got some big clear nylon washers which cover it but it does not look very nice tho!
I'm probably going to have to search for white washers that cover the corners of the square holes, I can't see any other way to do it :confused:
