I know I‘ve got a problem with very squeaky floors upstairs, but am just not sure how serious a problem it is.
This is an 8 year old 4 bedroom Cornish house built in traditional block-work with painted rendering. The upstairs floors are unfortunately chipboard. The original builder screwed the boards down but did not glue them down.
From early on we had developed squeaky floors in the upstairs hall and bedrooms. I hired a chippy in for a day and together we screwed a lot of them down with more (longer) screws. They stopped squeaking for a while but it soon returned.
Since then I have had a couple of goes myself mimicking what he did and each time it improves it for a while but then the squeaks return.
Meanwhile I had to get another chippy on for a day to stop the staircase from moving. He found the builder had put the bottom dog-leg of the staircase together with nails instead of screws and did a great job putting that right. While he was there I asked his advice on the upstairs squeaks and he said it may not be the boards but maybe the main support timbers have shrunk and it is them that are causing the problem. If that is the case then that strikes me as being a major job as all the upstairs walls are constructed on top of the floors.
Am I right in being concerned? Is this a likely explanation? What will I need to do to investigate? And is this sort of thing likely to be covered by NHBC (which has 2 years to run).
