Squeaky sub floor
4 Apr 2014
Michigan
Several years ago I commenced to building my own house, and never quite
finished it. That said, now I need to lay some hardwood flooring down
over the plywood sub floor. My sub floor was fastened onto the joist with
regular 8 penny nails and construction glue. The floor is very squeaky at
times. My question is would it be a good fix to throw some drywall screws
down next the existing nails, or some ring shanks with me nail gun, the gun of course being the easiest
A number of questions if you dont mind:
Was the floor left exposed to the elements for any length of time?
When did the heating first come on?
Is your sub-floor 3/4" T&G ply?
Did all ply joins land on joists or blocking? What kind of joists?
Are you certain that the joists are firmly fixed - is there any bounce or sway in the floor?
Your local Building Code will specify the correct screws - use screws and be alert for nail pops - drive all nail heads down. Dont use drywall screws.
You must fix all squeaks etc. before laying the hardwood finished floor or you will compound the problem.
Thanks for getting back with me. The answers to the question are as follows.
It is unweathered 3/4" T&G, it might of mean exposed once during construction but for the most part stayed dry. House build in summer
and heating season begin in early October.
2 x 10 Joist here used.
No bounce in floor.
The Ply did land on the joist centers.
Just curious, why not drywall screws. or ring shanks
Drywall screws have the wrong thread, are too fragile, and could snap.
Ring shanks are, typically, good for underlayment but not subfloors - you've already run into difficulties with nails, dont compound the difficulties.
Presumably, 2" x 10" solid joists?
If you do what's been suggested then it should solve the problem.
However when you say its "squeaky at times" then it could be a heating or swelling/shrinking possibility?
See what happens and come back here if you need more advice.
It is just a tiny bit squeaker during the dry winter mouths. I will take your
advise and get some good fasteners. Thanks again for your input.
I've used talcum powder in the joints before to good effect, it dry lubricates them and as you're probably aware talcum powder works it's way into everything...pinenot :)
