Help.
I have been blighted by squeaky stairs since i moved into my 9 yr old house, I have spent the best part of today dealing with these and can say i have tackled 90% of them.
The squeaks have gone from the treads/risers and now appear to be coming from the stringers, both sides flanked by plasterboard.
I have had a closer look and there is a variable mm gap between both sides and to hide this the builders have nailed on a decorative moulding.
I intent to remove this in order to combat the squeak then replace it when done, the question is , whats the best way to eliminate this problem. I have had two suggestions,
1- slap loads of pva down the gap or
2- slip some expanding foam down to compress the gap
Anyone have any other ideas or tips that have worked
