- Joined
- 23 Dec 2019
- Messages
- 43
- Reaction score
- 2
- Country
I've read many of the previous threads on this topic, but what can be done in my specific case?...
The boards in my new extension upstairs bedrooms are (3 months after project completion and full payment) squeeking like crazy pretty much all over. (I paid extra for 'sound-reducing' insulation to be installed here, and so having an in-built noise source is highly irritating. I've taken up (rolled up) the recently laid carpet to examine things.
As I already knew, they are T&G 18mm 240cm x 60cm chipboard boards, very tightly screwed down with a lot of long (6cm) screws.
When I walk along one of the boards, the creaks appear to sometimes come from that board itself, but at other times can easily come seemingly from neighbouring boards, so the stresses causing the creaks are (sometimes) being transmitted across the T&G (I think).
I've removed all the screws from one of the boards.
I doesn't seem to have changed things at all. Walking on that board still causes random squeeks all over.
I've noticed that the screws have 'full length' threads, and the boards themselves have only been drilled with a smallish hole (ie., they are not clearance holes).
But I don't think the squeeks are coming from the screws - I think it's from the T&G fittings themselves between the boards.
I've seen lots of people mention talc powder as a lubricant, but presumably this needs to be applied during construction, rather than retrospectively? All the joints seem way too tight to allow even talc to penetrate. And WD40 would presumably just be absorbed by the chipboard, rather than penetrating down to the T&G itself.
I've a multi-tool and I guess I could try cutting off the tongues, but that sounds risky and is a great deal of work.
- solutions for me to try?
- are there specialist tradesmen who would be prepared to look at this? How would I find one? (I mean, an experienced specialist, rather than a general carpenter / floorer) Would it be worthwhile?
Is ripping it all up and installing 'proper' planks really what I'm going to be told?
I'm under considerable pressure to get this sorted so we can finally move into the new, 'dream' bedroom. (!)
