A
angelf
My ST699 honeywell programmer just went last night. Replaced 3 amp fuse, & secured brown earth wire inside programmer which was loose-it started then blew again. Got a replacement ST699 today as circuit board was brown at bottom right hand corner of old programmer as u take it of the wall & turn it round to look at it. Again it started then same thing occurred. Any ideas on what is causing the fuse to blow? Any ideas on how to fix it? Boiler does start up each time. Am recently Corgi registered & would like to see if I could fix this problem myself. System is a basic gravity hot water/pumped c/h system with no room thermostats in house.
Any help would be appreciated. M
