Hi, I have recently put down an engineered oak floor, 6mm thick top layer. It has gone well with 1 minor problem. On the last few boards that could not be secret nailed, I used screws that were countersunk into a pre drilled hole. I then filled and sanded the hole with a wood filler that roughly matched the oak colouring.
All looked ok, but when I oiled the floor with Treatex, it has brought out different colours between the floor and the filler. It has also exposed areas where the sanding of the filler was not a thorough as I thought, and has smudge marks around the hole.
Any ideas of how to correct this? Is the only way to do some serious sanding and then re oil the floor?
