staining a colour advice
17 Aug 2004
Hi i have put up on my kitchen wall tongue and groove paneling and all new pine doors and arcatrave, as it's in the kichen i want to give it some protection, the kichen is going to be on a mexican feel so I would like to stain this with a hint of teracota, what the best products to use for this or any tips on what I should be using.
I still what the pine to be very prominent, but with the hint of teracota or red and it must be wipable and half way bay resistant :)
Thanks for any advice
a few pointers new pine is very" white" it will darken with age
if you use oil based varnish they yellow with age use acrylic [waterbased]
are your "new"pine doors pine or pine effect
big all
I always used to use an oil based dye but found a water based dye to be better.
I then finish with a couple of coats of Danish Oil.
I used to use varnish but wont use it anymore.
Wood is alive and oil keeps it that way.
Hi, thanks for the quick replys!
The doors are pine louver doors
I don't want to use varnish either, don't like the shiny effect you get, wood like to keep it as natural as possible!
Any makes you would recommend?
well as dewy says danish oil
and you can of course use mat varnish
big all
