Think this is the best section?
Anyway, looking to get the chimney lined with a 6" stainless liner. We dont really use the fire that much, but as I have scaffolding up there for re-pointing the chimney it makes sense to get it done.
I see there a different grades of stainless 316/316, 904/316 or 904/904.
Is it best to go for the best? I have found a 904/316 with a 20 year guarantee for £18 per meter. other wise 316/316 for £15.50 per m.
We only burn wood and sometimes coal, but only for very cold times or Christmas for effect.
See pic below. of our stove with false chimney hood removed.
Forgot to say it is multi fuel wood burner, fitted about 30 years ago. The top of the stove is hidden behind a false removable
The pipe going back into the wall is 7", which I then assume joins the main chimney. It is regularly swept.
Would I just bring down the stainless liner, and then remove the 45 deg bend section and connect the stainless liner to the top of the stove via a 6 -7" enlarger unit?
