Hi
I'm planning on some recessed lighting in the wall along my stairs, just above the stringers. I've been Googling trying to find appropriate fittings, but all I seem to come across are LED units with integrated bulbs that can't be replaced. I'd rather not use these as it will be a pain having to replace the whole set when one fails - which I'm sure they will at some point, I've not found LED bulbs to be as reliable as they claim!
Anyone got any recommendations of fittings to look at, ideally with a replaceable bulb? I was looking for something with a G4 or similar as they only need to be small, but not having much luck.
I'll be fitting them in the walls above the stringers which is plasterboard dot and dabbed onto block.
Thanks!
Burt
Thanks!
Burt
