Stair treds of different heights?
3 Feb 2016
hi all.
Was wondering if you could have an L shaped stair, with each flight with a different tred height?
I can't find anything for certain in part k. It says each flight must be the same height, and each flight is a run of stairs separated by a landing.
Does the 1m square at the corner of the L count as the landing?
Further info... The first three steps go up 600mm to a small landing... Then there is a door off the landing. The stair turns 90 degrees.
Then there is a flight running up to the first floor.
In my opinion as long as the risers and goings in each flight was consistent then the staircase would comply. It specifically defines what a flight is and that the risers on each flight that make up a staircase should be consistent. It does not say every single rise between floors must be the same.
Technically, it may be compliant, and I accept that in a refurbishment project you may not have much choice, but personally, I would consider it a mini-failure if I designed a flight of stairs with a landing in which risers were of different heights.
I think that would be OK if the flights are separated by a landing, but stairs are often the 'grey area' and much depends on how the inspector sees it.
Maybe, however the term 'flight' is defined in Part K as a series of steps in between landings.
I thought there was something in the regs which stated the minimum accepted area for a landing to be classed as so.
I was always under the impression that that wouldn't be sufficient and that for the two associated flights to be described as distinct required a larger area to break your stride.
Although I have had a good look and can't see anything other than the square of the width, must have been imagining it
I can't remember the technical requirements, but I agree with the spirit of chappers's remarks. If you don't break your stride, then the stair may seem a little awkward. That said, old cottages are always full of these idiosynrasies - I guess you just get used to it.
A flight is a continuous run of steps. If the run is broken by a landing (that complies with the definition of a landing) then you have two flights and each flight may have different risers. How comfortable it would be is another thing but it would comply.
Interesting, thanks guys.
I don't really know what the real answer is, other than its a little grey and kind of bad design. I can't find anything that specifically says each run must be a certain distance from the other to be counted as a different stair, but an inspector said it has to be a meter away.
There's nothing in the regs however. If anyone finds anything please let me know!
