I am fitting 28 downlights into my stairs 2 on each step,
I have cut the holes for the lights and i have the downlights,
What wire would be best and do i need transformers
i am using the following bulbs
1watt GU10 2pin LED Colour Change
Prod. Ref. #: PAR161GU10LEDCG
Features:
1watt 240volt GU10
Average Rated Life 30000hrs
Effective Ambient Colour Changer
For Display Effect and Stairway Lighting
Not suitable for use with Dimmer Switch
Dimension: L=55mm; W=50mm
If transformers are needed would a have these behind each bulb??
Features:
1watt 240volt GU10
