Evening all,
Is it feasible to install a stand alone rcd to a ring main by removing ring from 32amp mcb at cu, extending both legs of ring(using crimps) by a few inches into rcd out terminals. Then using 6mm from the 32amp mcb at cu connect into rcd incomer terminals.
Unable to use rcbo (that would just be to easy wouldn't it) as the only rcbo contactum do is a double module, you've guessed it there are no spare ways on the cu.
