I need a new DG unit for my window, it's cracked on the inside for some reason ( manufacturing fault? windows were new 2 years ago and I never open those curtains, noticed it was cracked just before xmas.. )
got the beads off to measure the actual glass size 750ish by 400ish ( got the exact written down somewhere.. ) but without actually getting the unit out I don't know exactly how thick it is..
I can stick a steel rule down the side for a rough size, but I'm unsure if it's going into any recess etc on the frame or sitting on a bead of silicone etc..
so is there standard thicknesses so that if it's say 27mm on the rule then it will be a 25mm unit or if it's 29 then it will be 30mm etc?
