Standards for embedding the mains cold water pipe in a solid wall ?
3 Nov 2020
Hi
Is there any standards for embedding the mains cold water pipe in a solid wall ?
As part of our complete house refurbishment the entire plumbing system was replaced. In cold external & humid internal conditions, dampness formed in the plaster following the line of the mains cold water pipe in the kitchen wall. The builder eventually investigated and found the subcontractor have not used any insulation, thus allowing condensation to occur. A new in house plumber has now cut the pipe in & added insulation, but following cracking of the filler the insulation appears to be within 1-2 mm of the surface. Is this common practice /acceptable?
Your views would be appreciated
Thanks thats very useful, i assume that the equivalent rules apply in England?
Yes, both, England is the first part of the title "Water Supply (Water Fittings) Regulations & Scottish Water Byelaws"
Sorry, my mistake...its obvious when you point it out
The new pipe work has been embedded in an external wall, which i assume is why we experienced condensation on the pipes, resulting in the damp showing in the plaster. The addition of insulation now seems to be a way to compensate for what appears to be a breach of the regulations.
(the old pipe work was boxed in on the surface..... I understand why now!)
Our cold supply was buried in the wall, great idea until it started leaking!.
I ran a boxed in pipe up to 1st floor then had to pull a load of floorboards up to connect it to the other end.
