- Joined
- 11 Jan 2004
- Messages
- 43,859
- Reaction score
- 2,868
- Country
Hi guys.
Just working out a few bits and pieces to put some DIY wiring in a static right.
First, I can't find any data on the dimensions for a 2 foot flu: what is the length in mm.. is it actually 600mm? Id like to fit one in a boiler cupboard but the width is 23".
Next, I am redoing a lashed-up DIY wired lighting set up with two table lamps, one in each corner of the sofa in the bay window. It's run in flex under carpet from a socket and behind sofa fabrics and cushions. Currently, each table lamp has an in-line switch.
My proposal is to trunk cables round the top of the U shaped sofa where there is a white PVC trim and a lip, so they will be well concealed, along with trunking along the wall to the socket.
At each of the open ends of the "U", I plan to put a 2 way switch, so switching the lamps on and off can be achieved easily wherever you are sitting.
I will keep the inline switches in case only one lamp is needed.
I can fit 25mm trunking in the lip across the width of the static and part way round each cormer, but if I use it, I will have to step down to 16mm because the side windows foul the trunking run.
Alternatively, I can use 16mm throughout.
My dilemma is how to wire the circuit? I am starting with a double socket on a B20 radial.
I can't have any joints or concealed cable (other than in trunking) near the sofa area.
All my joints really have to be in the switch boxes.
The table lamps are Class II, so are wired in flat twin flex.
It would make sense logistically (if not electrically) to take each of these lamp flexes back to the nearest switch box), otherwise the trunking will be filled to overflowing.
Apart from the lamp flexes, I am using singles.
Any ideas, guys, please?
Cheers!!
Cheers!!
