Hi there,
I am about to fit a magnetic catflap into a upvc. I have marked out the size and drilled four holes in the corners for the jigsaw, however, it seems the panel is metal and I need to get a metal bit for my jigsaw.
Before I do so i would like some advice. CAn i cut the hole out with an angle grinder instead or is this overkill??
Because the flap is magnetic and the door panel metal, I have to fit a wooden frame in between the door surface and flap. Does anyone know how thick this should be. Does the frame have to go on both sides or just one?
Answers to these questions and any other advice from someone who has fitted one of these devices would be appreciated.
thanks in advance.
thanks in advance.
