if the rust stains are on the surface then you should be able to remove them. If not, it is time for a new bath
My bath is "plastic" but a few years ago I bathed after cutting up a cast iron bath with an angel grinder. The next day there were loads of rust spots. I ignored them, and in time they disappeared.
Bleach will not remove rust. Baking soda and water may remove their spots of rust if they are on the surface.
