Hi guys, i'm needing advice as to the size of an "I" beam I want to use for a roof apex.
This does not involve building regs as its for an out building and the roof covering will be light weight poly-carbonate panels as a conservatory type roof, with 4x2 timber rafters between the panels which are 2.4m long before resting on an existing brick wall on the other end.
So given the light weight of the roof, I want an "I" beam that is thin enough but strong enough not to sag at a 4.5m span, to use as an apex support for the polycarbonate panels.
I could use timber, possibly 9x2" at 4.5m long, but im prefereing something thinner and stronger.
Any suggestions?
Any suggestions?
