hey.
Halfway through replacing the handrail and spindles on my brothers staircase. He's had an idea that using steel cable running horizontally between the newls would look rather spiffy instead of regular, vertical wood spindles.
I've seen it a few times in poncey restaurants etc.. but don't know how it would work in a domestic setting, what with the 100mm rule for spindle spacing. Is it allowed under BR's? Has anyone done this?
I've seen a similar design on stairs using 100mm planking instead of cable. Fairly sure the space between the planking was more than 100mm.
The height between floor to underside of handrail is 850mm. handrail lenghts are 2.90M, 1.70M and 0.90M. Newl posts are 92mm x 92mm. I would probably be using 10mm cable.
Thanks.
WC
Thanks.
WC
