I'm putting up an external ariel and running the drops down the side of the house.
As it enters the main living room (1st floor) I would like to protect the cable with some galv'd steel conduit.
TLC near me stocks it cheap enough but I don't understand one part.
If that's at the bottom of the run covering the hole of the entry into the property - how are you meant to get it through the casing? Drill it?
I can't see any "lids" with holes in them for a compression gland.. i.e.
Yet I see this rubber gasket with a hole
Any ideas?
Any ideas?
