Hi
I have a gravity fed hot water system with a galvanised steel cold water tank that feeds the hot water cylinder only i've read some feed cold water taps too but my tank only has 2 pipes out one is the overflow and one goes into the bottom of the cylinder the water tank has corroded quite badly and has started leaking only a pin prick I suspect but its time to replace it.
my main concern is if the leak gets big enough to drop its entire however many litres of water so have drained the tank by isolating the water to the tank and opening the hot tap until it is almost empty I suspect this means the cylinder is empty too and there is no way of isolating the cylinder from the heating system ( very basic ideal mexico floor standing boiler single mechanical thermostat in hallway and mechanical time switch)
My first question will the coil in the indirect cylinder over heat and get damaged?
second Have I missed a way to isolate the cylinder ? or third will i simply have to switch of the boiler and put a jumper on
its going to be a few days before the tank can be replaced but don't want to cause any damage in the meantime
sorry for the long post and thanks in advance
