Hello: can you please advise the correct type of steel lintel and the weight of the lintel for the following:
9" solid brick lime mortar wall.
Structural opening 2400 (plus 300 bearing surface) = 2700mm.
Load on lintel outer leaf: wooden wall plate supporting roof trusses plus ceiling joists, slate roof.
Load on lintel inner leaf: 3 courses of brick only.
Both of the 9" wall will be finished with interior plaster.
Thanks, Peter
Thanks, Peter
