steel pipe to copper
15 May 2008
Blackpool
hi. was wondering how do you join a steel pipe to 15mm copper pipe? what fitting would i need? many thanks
is that end feed bsp femALE? i assume the copper has to soldered to the fitting rather then compression? thanks
If you search through the pages you will find the equivalent in compression
Conex 302 male iron x copper compression
Conex 303 female iron x copper.
Conex 402 & 403 are the bent equivalent
