Had a pir exterior spot that used a incandescent lamp but the unit started to flicker and then packed up so brought a steinel spot one with pir sensor to replace, before installing checked power and polarity to outside and fitted the steinel light which tripped the rcd for the ground floor lights, cooker and shower so checked that it was wired correctly again and same thing tripped the rcd, strange i thought so took the steinel down and temporarily wired a 60w incandescent lamp in and the lamp lights and no tripping.
Power for the light is taken from what used to be a lobby light but that was redundant since moving the front door outwards years ago and the old light worked without problems till it packed up, for testing i have a no contact buzzer/tester and a basic multimeter.
