Can i put a step in a drain run? Down obviously not up, i would assume it needs to be rod-able from both directions but would it work?
I have a reinforced ground beam to get over. The invert of the drain is the same height at the middle of the ground beam so i was proposing 110mm pipe over the groundbeam, 2 90 degree bends to make a 'step' and then i can be at the correct level for the drain?
