Hi All,
I wonder if someone can help with some fault diagnosis on my alarm system?
I have a Pyronix Sterling 10 system with LCD keypad and Cequra external sounder, several PIRs and magnetic contacts. System is over 16 years old but has been extremely reliable. New panel battery fitted Nov 17.
Unfortunately the system went off on Christmas Day (yes, I know!) whilst we were watching the telly - it was not armed. It could not be silenced with the user or engineer codes and was showing the '!' (exclamation mark) fault symbol on the keypad. I switched off the mains power supply, opened the main control panel and disconnected the back up battery. This silenced the internal sounder but the external sounder continued until I opened it and disconnected the battery in it as well (bit tricky up a ladder in the dark half cut with a torch in my teeth!).
The only other thing I noticed was that the external sounder was making a sort of squealing sound, not the proper siren sound. However, when I powered down the control panel (and disconnected the battery) this squealing changed to the normal siren sound.
Anyway, my main question is what could have caused it to go off suddenly like this?
Obviously something has failed so I would like to try and identify what and would be grateful for your suggestions of what to look for and/or how to diagnose the problem.
I have looked through previous threads but have not been able to find anything relevant.
Hope you can help.
Many thanks.
Hope you can help.
Many thanks.
