Hi, I recently had to install a new pyronix sterling 10 circuit board as my other decided to pack in. I fitted all the wires in exactly the same place as they were on the previous circuit board as all the connections were in exactly the same place. (just thought a simple exchange would work!)
I powered it up and all was fine. The problem I have is when I go to arm the alarm and enter the factory code (will change later) the alarm just goes straight off with the LCD display saying Personal Alarm.
I have double checked all the wiring and the only thing i haven't done is to install the new LCD control panel which I received with then new PCB.
Is it necessary to install the new LCD panel or is there something else causing this to happen?????
Many Thanks for your help!!
Jon
Jon
