Hi All,
We have a Sterling 10 Alarm System, which is +20yrs old and we've not used for last couple of years. If electric trips, it starts to beep so just click button on pad and that stops. I want to take out, but am worried the sirens will start and I won't be able to stop them!
After researching online & here, my thoughts are as follows:-
1) Switch off relevant circuit breaker in fuse box.
2) Open main board, sirens start, re-enter code in key pad to stop. Is that right?
3) Remove battery and fuse in spur next to main alarm box?
4) Isolate power cables in main box and then start to remove room motion sensors, etc.
Other info :-
Outside box/siren, doesn't sound when power cut, could this mean battery knackered and shouldn't cause a problem? Did have to have battery in main board changed +10 years ago due to it being on it's way out.
Also, there's a mains power siren in hallway, if there's no power/battery back up will this just want removing?
Sorry for all the questions, but hoping you guys can make this job painless!
Thanks in advance.
Jonah
Other info :-
Thanks in advance.
Jonah
