Sterling 10
22 Sep 2009
Nottinghamshire
Evening All,
Got a Pyronix Sterling 10 that just shows 'NVM' in the upper left hand corner of both keypads.
I guess its trying to tell me it has a problem with its Non Volitile Memory...... but what exactly? Corrupt?
Panel seems to work Ok though!
Any ideas?
Did you ever find the answer to this, I have a customer with the same issue so can't change any settings as NVM is constantly showing.
The issue started after a power cut and the back up battery went flat as it was old, the battery has been replaced and the NVM reset procedure performed. this has reset all the codes to default but additional setup can't be completed.
Thanks in advance
Alas, No. I never did get to the bottom of it. Even tried calling Pyronix tech support and they couldn't help me.
In the end, I changed the panel to a ADE G4.
Thanks for the info, I suspect the power issue has fried the main PCB so will recommend a replacement.
George
Very often Non Volatile Memory is a normal memory chip supplied by an on board battery when the power fails. This can be a button cell soldered into the PCB
Replacing this and reloading the RAM contents restores normal operation.
Sometimes the battery is built into the "chip" and this requires the whole chip to be replaced.
This may or not be applicable to the alarm being discussed.
