I have removed a thick quarry tile from my window seal because it was coming out loose. I want to stick it back on but the mortar that was used as adhesive on the window seal is very hard to remove and I don't want to try and break it and cause too many vibrations that will affect the rest of the tiles. I will need a bit of adhesive of a thickness of 1mm though to make it level with the rest of the tiles. I've got a bit of cement, could I use that or should I really use something else?
Thank you.
Thank you.
