Recently been having problems with the hot water not turning off when it should.
Noticed that when it comes on the actuator (the system has two 2-way valves - one for CH one for HW) on the hot water feed clicks loudly and does not return when the water should go off.
This seems to also keep the boiler running until the valve is closed.
I've had the cover off the actuator and it looks ok but still didnt close until I pushed the little arm to close it.
Even with the power to the controller off, the water will stay on until either the valve closes or the boiler is turned off.
Any ideas? Is it as simple as replacing the actuator?
Its a Siemens DVA2/5 actuator.
