Right, help needed. I have needed to remove the back ( tiled) wall of a shower cubicle in a loft conversion. The Builder had used normal plasterboard glued onto 25 mm Polystyrene that was dot and dabed onto the part brick/part block wall.
The whole lot was sodden, and fell apart as I removed the tiles.
So the plan is to use 25mm celotex, then 12mm cement backer board.
The question is how do I fix to the wall?
Cheers
Alex
Cheers
Alex
