Sticking down vinyl flooring?
7 Jun 2021
I'm going to lay some vinyl flooring in a bathroom which I have boarded with ply, is double sided tape the way to go & do I just need to put it around the edges only?
If you just do edges it can ruck in middle .
Sheet vinyl should be able to loose lay with sealant around the edge, if you perimeter fix it, just spray suitable spray adhesive onltwo adjoing sides of the room allowing the vinyl to expand if it needs to.
