Started a new thread as thought it would be easier.
Strimmer a pain to start.
After getting it started I can use it fine no problem.
I switch it off & reload the line.
Now I go to start it again bearing in mind it’s warm & I’ve been using it for say 15 minutes.
Pull after pull after pull.
I remove air filter which is new & pretty much next pull or pull after it starts.
So removing air filter I am making the tool run weaker ?
Basically what does that tell me about the
Mixture.
Mixture.
