- Joined
- 27 Jan 2008
- Messages
- 24,535
- Reaction score
- 2,808
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Idea was cool at night warm up in the day, but simply not working. The problem is getting hot water to the rooms in the morning, the valves open OK, but there is simply no hot water flowing from boiler.
So boiler control is a time switch and a wall thermostat in the hall, the hall had no TRV fitted until yesterday when I fitted one to try and stabilise hall temperature. So last night the wall thermostat set to 17°C the remote thermometer sitting on the thermostat was showing between 17 and 17.3 degrees, the hall radiator was tepid, 6 am central heating turns off, and 7 am back on again at the same time as the eTRV's change temperature, idea was turning the heating off and on at these times would ensure boiler was running when the temperature changed, it did not work.
So went down to check what was running and both uncontrolled towel rails and the controlled radiators were just tepid. Outside temperature dropped to 6°C now 9:50 am at 10°C. So raised temperature on the thermostat to 18°C remote thermometer sitting on the thermostat is showing a gradual raise in temperature. I can hear the boiler cycling on and off, upstairs over temperature 22°C in my bedroom radiator cold. The radiators down stairs are warming up by 10 am the hall radiator and towel rails are hot, but not at full temperature. The two radiators with eTRV are now at full temperature.
However both eTRV's showing 17°C the camera in living room also showing 17°C and the baby alarm in the bedroom with eTRV is showing 21°C although on the wall with the hall radiator on the other side of it. The thermometer is showing hall climbing now 10:10 showing 17.7°C so very shortly with thermostat set to 18°C the boiler will cut out.
It would seem allowing the rooms to cool to 15°C over night was going too far, it simply can't warm up again, tomorrow with hall set at 18°C it is still going to be a problem simply as boiler is not running, so it would seem 17°C to 19°C night and day temperatures are about the maximum differential I can set with a hope of it warming up in the morning. Seems rather pointless having eTRV's fitted? Unless the thermostat is also programmable and can alter temperature at the same time.
I have reset temperatures and off times for another run tomorrow, set minimum to 17°C on the two eTRV's and increased the off time before the change to 19°C but to be frank 2°C is hardly going to make any difference to comfort or energy used, so in real terms they have been a waste of money. And this is with outside temperature at 6°C at night.
I can see they may work upstairs, the bedrooms and landing upstairs seem to get a lot hotter than downstairs, the only house I have had where upstairs did not get too hot used hot air central heating not water, and the ducts must have leaked as it cost an arm and a leg to run.
Odd as I have been writing this, hall temperature went up to 17.8°C then dropped again to 17.5°C boiler still running. May be a delay in the standard TRV turning off? Seems just too many variables, from lock shield valve to TRV to thermostat will I ever get it right?
