to follow up from my previous thread regarding radiators-i have dug up the floor for access so the plumber can solder the pipes to fit the rads.where the tails go into the radiators there is a very slight leak?he said that as they are taper threads ptfe tape should not be used.the tails are in the rads very tight but are still passing slightly.what would be the best solution.thanks.
