i have a low level stone resin tray to install. It is on a wooden floor first floor. The floor is green chipboard, screwed down every few inches. The drain is fitted below and routed through a reinforced joist. My question is does the tray need to go on a mortar mix? Or can it go straight on the boards? I have read various threads, the tray is very level on the bottom side.
Also as it's a low level tray and the waste is below the floor does this need to have access? If so how can this be achieved? The floor is to have click fit laminate fitted. I was going to sort out the waste and test for leaks and set at the correct level for the shower tray. Then place tray on top and screw in the top part sealing with plumbers gold. I have seen the waste fitted first and the lowered in to place and then connected up. Which is the best method?
Thanks for the help.
