Stop resin bond from being porous?
21 Jan 2017
Hi
I have a summerhouse on a concrete base that recently had patio stones laid around it and so the summerhouse is now below the depth of the patio.
Where the patio meets the summerhouse is a resin bonded grout that I was told was non-porous however its definitely porous! What happens when it rains heavily is the rain soaks through the resin an runs under the summerhouse
I sealed the slabs (and I thought the resin too) with a patio seal but its still porous - any thoughts what I could use on top of the resin please?
I was afraid someone might say that, almost impossible now
if that a problem you could remove the paving joint so the water can escape.
that would be my answer ,along with cutting a deep groove into the concrete if possible.
would that help?
Sounds like a possible - maybe drill some holes though the concrete to allow drainage too? You dont think it would be possible to prevent the water getting down there in the first place somehow?
