Stop Tap/Lead pipes
2 Apr 2008
One of our stop taps is embedded in the wall and is difficult to access. It is dripping an needs replacing. It is connected to Lead pipes. Is it a task I should take on myself or is this something I should leave to a plumber?
I am a bit concerned because a lot of plaster will need to be take down to allow some room for movement around the tap. So as an alternative I was thinking os "sealing in the tap" and maybe putting another one higher up the water pipe. I assume it is possible to weld? in the tap and seal all of the gaps?
hack the plaster off and replace the tap use a lead loc fitting
sealing it in is asking for trouble ;)
