Morning!
I've got 2 tiny leaks in my new pipework at the points arrowed.
View media item 94596
Top left - New compression fitting on 4 inch bit of 22mm pipe to a flexi hose. Used 5/6 wraps of PTFE on top of olive. No drips on the floor overnight but I can see a bead of water under the nut.
Bottom right - This is a very old nut onto a new brass tee. Original olive with same PTFE as above. No drips again and not even a bead of water, but I can just make out a ring of moisture under the nut.
I really don't want to recut any pipework and the nuts are nipped up as much as I can (maybe a bit too much).
- Can I dismantle the joints and use a jointing compound like LS-X to fix?
- Should I redo all of them with LS-X for a belt and braces approach?
Any advice welcomed, apart from "redo the lot with solder", it is what it is!
Cheers...Dan
Cheers...Dan
