Is this a ridiculous question... We had a plumber out recently to change some upstairs taps and one of the things I asked was if she could switch the old stop cock to a quarter turn tap because it was leaking i.e. dripping from the tap, also it didn't seem to turn the water off completely, just slowed it to a trickle - however she couldn't switch the water supply to the house off and needed the water board to do it but instead tightened the tap which stopped the leaking. She returned to change the kitchen tap so must have managed to get the water off. However I've just had to replace the washing machine and tightening the stop cock didn't switch the downstairs water off. The upstairs water went off completely -took about 2 mins. But after 10 mins the downstairs water was still going strong, maybe slowed down slightly - does this sound like a broken tap still? Or am I being daft? Could it take longer to drain the system?
Edit - probably Important information: definitely sounds like water rushing through the pipe with the stop cock on it. Could plumber have tightened with a spanner to stop the water - the tap is as tight as I can get it by hand.
