As the title says weve got a 30 yr old stopcock and the main pipe is plastic coloured black and im assuming 20mm???
Its got a slight weep from the bottom nut and weve tried wrapping tape around both olives top and bottom and still the same problem. So im thinking time for a new stopcock, what sizes do they range from and what size would you need for a 20mm plastic pipe ie. 25mm/15mm, 15mm/15mm etc
