Redoing the kitchen and plasterwork at the moment and have just removed some cabinet carcasses. I've always wondered where the stopcock was and I found it behind some units. Boxed in by previous owners and completely inaccessible.
However, the nightmare is that it seems to be leaking. Not a lot, but there's a damp patch around the bottom of the pipe about 8" in diameter. From what I can see it's seeping along the thread around the gland where the valve spindle goes into the body. It's drying as fast as it's leaking as there's no sign of water damage but it's not a good situation.
The incomer is original cast iron or steel by the looks of it and the stopcock too. It is not in bad nick but I can't budge it and am scared to give it laldy for breaking the pipe because then I think I am uber-screwed with a broken main pipe just above a concrete floor and looking at a whole new mains pipe. And a 2 month delay to refitting the kitchen!
I can easily fit a new stop valve further down the pipe but what are my chances of sorting this leak without removing the stop valve? I just know that will go wrong and I'll be stuck until I get a new main.
Can I grab the valve body with a grip and try to get a 1/4 turn on the spindle thread? Can I remove the spindle without water ****ing out and repack it?
Really appreciate any advice while I research the problem or try to find a plumber!
Jock
Jock
